CRT G. Saturne
 MessagePosté le: Mar 26 Avr - 15:37 (2016)    Sujet du message: CRT G. Saturne Répondre en citant
Frequency range
depending on version: 26.065-28.305 MHz
25.615-28.305 MHz
Channels/tuning steps
depending on version: 200 (5*40)
240 (6*40)
Mode:    AM/FM/SSB/CW
RF output power: AM/FM/CW: 10 W
SSB: 21 W (PEP)
Frequency control: PLL
Power supply:    Mains
Antenna impedance/connector: 50 ohms / SO-239
Other features:    NB/ANL, Echo chamber, Roger beep, +10 KHz switch, SWR-meter
RECEIVER SECTION
Receiver system: Single conversion superheterodyne (SSB)
IF: 10.695 MHz
Double conversion superheterodyne (AM/FM)
1st IF: 10.695 MHz
2nd IF: 455 KHz
Sensitivity: AM: 1 uV (10 dB S/N)
FM: 1 uV (20 dB S/N)
SSB: 0.2 uV (10 dB S/N)
Selectivity: AM/FM: 4 KHz (-5 dB), 10 KHz (-50 dB)
SSB: 2 KHz (-5 dB)
Image rejection: 50 dB
AF output power/speaker: 3 W at ?% distortion / 8 ohms
External speaker connector:
TRANSMITTER SECTION
Modulation system: AM: Class B collector modulation
SSB: Double balanced modulation
Max FM deviation: ±1.5 KHz
Spurious emissions: Less than -60 dB
Microphone connector/impedance:    4-pin / 600 ohms
Manufactured: Taiwan, 199x-199x (Discontinued)
Source: http://www.rigpix.com/
 MessagePosté le: Mar 26 Avr - 15:37 (2016)    Sujet du message: Publicité
